mariner magnum II 150
louism
Help. Need to know year of Mariner magnum II 150 #0b314774 and if anyone has wiring diagrams.As well as what repair manual is needed and where to get it. thank you. louism
j_martin
Re: mariner magnum II 150
It's about 1988 or so. It's the same engine as an XR4 except for paint. Stock LU is the small one, 4 1/4 in. hub.
Manual number is 90-97658-3
hope it helps
John
louism
hope it helps
John
Thank you John but not familiar with "stock LU and also the manual is from where and is it a clymer. I was also told that it might be the same as XR2? Thank you very much for reply.
j_martin
Mag II is an XR4, 2.4l engine. Right out of the crate they make about 162 horses. With a little trimmin of the heads, some good fuel, discarding the advance module and retiming it, 175 @ 6000 rpm is pretty easy to get.
The stock lower unit on either a XR2 or and XR4 uses the same prop as a 4 cylinder engine. A standard V6 lower unit using the bigger prop will bolt right up. Sometimes they got changed out.
The little LU is a real screamer on a performance boat, but it will sometimes put the pinion out the side if you surface a 3 blade prop. I surface a 5 blade and tear the lake up with no trouble. Be sure to run High Performance LU lubricant in it.
hope it helps
John
