donmcgehee
Thread starter- Joined
- Nov 19, 2009
- 3
I have a 1988 spirit 16.5' bass boat. It as three live wells, one in the front and two side by side in the rear. On the control panel, there is a toggle switch which you can move from manual to auto. Flipping the switch up will activate both pumps while moving the switch down will activate only the rear well pump. Below that switch, there is a knob that you can turn from min. to max. I have replaced both aerator pumps recently so both are brand new. When I turn on the switch to activate both pumps, the pump which fills the front well works just fine. However, the pump that will fill the two rear wells will turn on but will stop before the wells are filled. Also, sometime I turn on the pump and I hear the pump running but no water will fill the rear well. This problem is only with the rear live well, which is the largest. My question is does the knob that you can turn from min. to max. have anything to do with the reason why the pump stops before the wells are filled? How can I manually override this system so I can fill the live wells to capacity? Thank you for helping me with the issue.
