HarmonAviation
Thread starter- Joined
- Nov 19, 2009
- 4
My 1985 Yamaha ETXK 200 is getting intermittent power to the top left coil. (top R if your in boat facing engine) Wont fire at all when Idling down the "ICW" once she kicks in powering up on a plane, it catches n fires, trim up 1/4 the little Chapparal 198 CC shes attached to, really flys! 50mph easy. It has a racing foot with lowered pickup and bypass hoses W a racing prop.
I see the power probe to coil input wire light up on start up but no regular pulse or power to the coil at Idle. Spark tester dont light either (new plug, new coil) I traced it across the electrical J box and it turns into a blue wire that dissappears under the fly wheel. I havent tested the blue wire to J box yet, should I get voltage? Resistance? what? Its a "hall effect" right?
How do I get that wire to send power to the coil. Should I install a jumper across the J box? (the black block where all the wires meet)
