tgp***
Thread starter- Joined
- Oct 18, 2009
- 768
Re: Restoring a Starcraft '66 Nassau
As I ponder my next move on the rebuild. I thought I would solicit some opinions and advice on my transom replacement.
After searching and reading. From a cost standpoint I'm leaning towards 3/4 inch CDX, w/grorrila glue, to glue the two 3/4 inch pieces together (would screwing the boards together also help? and would I leave the screws in it when I install it?). Final trimming and sanding after material sets up.
The boat in question is 16 feet long w/ max 75 hp rating. The wood transom measures 60 inches wide x 12 inches tall x 1 & 1/2 inches thick with approximately 36 stainless steel bolts through the aluminum hull and transom plywood. Then seal with what your threads call penatrating resin??
Maybe marine plywood w/ gorrilla glue? I'm just not sure which way to go here. Your thoughts on this.....
Thanks again......
http://s940.photobucket.com/albums/ad241/tgp---/1966%20Starcraft%20Nassau/?albumview=slideshow
Thanks again......
