How to:What I did to Diagnosis & Repair= Blown head gasket 3.0L Mercruiser 4 cylinder
Status
Not open for further replies.
vegasphotoman
a fairly common repair is a bad headgasket, I go through on this thread what I did to diagnose and repair the problem. hopefully this will give you a little insite into this reapir, I spent 6 hours total start to finish repairing it
Here are all of the 34 pictures
Heres a mercruiser service manual PDF format, thanks DON S for posting the original thread in the how to sections!
My engine is a 1990 Mercruiser 4cylinder 3.0L carburated (gm motor)
my motor Symptoms
The motor Started running weaker as the season wore on, top speed was slowing down more and more, and some excessive oil was coming out of the breather into the spark arrestor. Seemed like alot of air was coming out of the breather when the motor was running, some is normal, but this was quite a bit, no smoke coming out though, which was interesting.
I checked the plugs, bit oil fouled, not bad though, cleaned and reinstalled, no change, checked eng timing, it was off a bit, hmm...re timed it, 8 degrees BTDC. When I revved it to see if the timing advance was working ok, the timing didnt move stayed at 8 degrees (using timing light) timing was not advancing.
Pulled the distributor cap, found broken springs in the centrifugal advance, replaced the springs using aftermarket Holley advance spring kit
Re timed the motor, now the timing was advancing, but still ran lousy and SOUNDED like it was out of time still.
Pulled spark plugs, did compression check, Max compression which is 5 motor revolutions
#1 140lbs #2 40lbs #3 42lbs #4 142 lbs....
so the 2 center cylinders were way low....poss blown headgasket! Shared cylinders with low compression is almost ALWAYS a blown gasket. that explains the excess air coming out of the breather and lack of power
Teardown
Removed water hoses, removed the front u shaped water pump hose so the water would drain out below the level of the block deck, that way water doesnt get into the oil/cylinder area when you break the head loose.
Removed carb and wiring, moved throttle cable and shifter cable out to the side, removed exhuast elbow, removed valve cover
Checked valve rockers for excessive looseness, very little play in rockers so that was ok
Loosened all the rocker arms, rotated the rockers out of the way and removed the pushrods KEEP THEM IN ORDER I use a piece of cardboard with some holes poked in it to keep them in order (the world wont end if you mix em up, but its best to put the pushrods and rockers back in the original location due to wear patterns)
Here the rockers are roatated to the side for removing the pushrods and now I can see all the head bolts
Remove the headbolts by de torqueing the head, that way you dont have a 90lb tight bold at one end and all the rest loose, could break a bolt or do some damge to the head. I loosened then starting at each end 1/2 turn loose, then working my way to the middle bolts working back and forth across the motor, once they are pretty loose go ahead and remove them completely
make sure all head bolts, hoses and wires are disconnected, its easy to miss the frt temp sensor wire, its kinda hidden under the tstat houseing.
I used a crows foot prybar to "pop" the head loose, if it is excessively stuck on there double check to make sure you havent missed removing a bolt or something.
Now that the head is popped loose, I hooked an engine hoist on using chain, the head with manifold is kinda heavy and In my situation it was a poss back breaker so I used the hoist.
Head hoisted out and I could see the headgasket WAS blown, see pic
Heres the Head surface
the cylinders looked good, pistons good, no build up of carbon, the cyl walls didnt have a very big ridge.
Onto cleaning up the parts, looking for damage etc
Cleaning up the block surface and head surface using a side angle die grinder and 120grit scrubber pad available @ (snap on, HF, autozone)
Ive found using these does no damage to the iron block, unlike a metal scraper which can cause damage to the metal surfaces of the engine.
my VIDEO on youtube of doing this here
once all clean onto checking head and block flatness
the mercruiser manual calls for .008 thousandths warpage over 6" as a max warpage acceptable. I used a straight edge flatness bar (I got mine from Snap on a long time ago) and flat feeler guage set,
Laid the bar out and pushed feelers under where the head gasket was blown, max feeler I could push through on the block on my engine was .003 GOOD TO GO
on the head I had a warpage of .006 GOOD ENOUGH no need to mill the head flat, if your head or block is past the specs .008 you need to have machine work done or replace the part, otherwise the headgasket will just blow out again.
I cleaned the head up using carb spray and compressed air,
didnt see any cracks in the head (look close!) , blew out the cylinder piston areas, make sure to blow out the areas around each piston well (dont want some foriegn material in the ring areas) I wiped it all down with a rag and carb spray, then oiled each cylinder wall with a clean rag and a little bit of fresh eng oil
See next post for the rest of the repair and assy
vegasphotoman
Re: How to:What I did to Diagnosis & Repair= Blown head gasket 3.0L Mercruiser 4 cyli
heres blowing out the cylinders, see the gasket material in the cylinders, get all that out!
Install new head gasket onto block, be careful placing the head back on, dont want to damage the new headgasket! a helper is a good idea on putting it back on.
Clean all the head bolts up on a wire wheel, put thread sealer (I used loctite brand $5 per tube, expensive stuff) on the threads, otherwise engine oil and water can get past the threads and mix. its a must do so DONT SKIP THREAD SEALER!
See your manual for torque order and specs, mine was 90lbs torque. Working from the center bolts outward back and forth, I actually torqued mine in 2 stages, 45 lbs on all of them, and then a final 90 lbs torque, so the head was eveny torqued down.
Install pushrods, making sure they seat onto the lifters, my engine required valve adjustment as such, tighten rocker arms until there was just a little bit of play (very little bit), crank engine around so cam lobes are on the low side, re checking over and over till all the valve rockers were adjusted.
install all the remaining parts in the reverse order of taking them off, exhuast elbow and gasket, valve cover, hoses, fuel line, throttle cable etc
change the oil and oil filter, install new or cleaned spark plugs, start motor.
Mine ran great right away, sounded good, double checked the ignition timing again to make sure thats all set right. 8 degrees BTDC good to go!
Adjust carb as needed (idle speed and idle jet )
Happy boating.
Heres a youtube vid of my motor 1rst start
and second vid of motor running
ErieRon
Thanks for that. I found it very interesting and helpful. I'm pulling my 470 now for other reasons and that's a great guideline.
vegasphotoman
Thanks Erie Ron
I was hoping it might be somewhat informative, motivate others to do the repair.. or atleast tear into thier motors and tinker if it needs it as some people are fearful, its all just science! no fear necc
Im not the best at explaining things, but I try...either way CHEERS and bottoms up to all!!!:D
see a MERCRUISER SERVICE MANUAL HERE PDF files
thanks Don S for posting this link!
cr2k
Also run a tap through the headbolt threads and blow them out. Not all of them go through to the water jacket. Tapping helps ensure an even torque by cleaning up the internal threads.
Nice post. I hope others will learn from it!
cr2k
You can also check your valves at this point by putting the head up side down (combustion chamber facing up) put some gas or solvent in the chamber and look in the ports to see if there is any leakage.
vegasphotoman
Kudos to ya Cr2k...good call
the tap out threads is a awsome idea (and its in the repair manual to do it)
and Im glad you mentioned this part = is to check the valves to make sure they seat well using solvent/gas... very very good idea!
I tend to blab way too much on my posts and was attempting to keep yap to a minimum...but those are both important things that I missed...THANKS!
system-f
I had to do this on my straight 6 (very similar to the 4 banger). The merc manual for my engine calls for the use of perfect seal on the head bolts which causes a huge gunk buildup in the threads. Also, check the head bolts, in my case they had to be replaced due to pitting and rust.
fat fanny
I had the exact same issue w/ my 3.0 LX and from this issue I became an I boats freak and learned pretty much everything that you posted in this thread when repairing this issue the hard way. But I'm glad that other can learn from this info so they do not have to go through the hard way (so to say) compression test is the tell tail Great post and info.
vegasphotoman
bump
JesterOMA75
Yeah I know it's an old post I'm replying to. I have a Mercruiser 140 with no power from the middle 2 cylinders. I have spark and gas, Going to check compression tomorrow. I'm betting the head gasket is gone just like this post. It makes the most sense. I'll check the valves in the way down. If that is the cast this post will be extremely valuable for me. Thank you for your good work! My son purchased this boat as is for us to work on together. So far we have completely replaced the ignition components and the impeller. So now it runs (poorly) and does not overheat. next up is getting it to run on all cylinders and find out where we have a small leak at the transom,
Status
