2004 Yamaha 60 hp, model: 60TLRC wiring diag.
JamesMc
I don't have an engine wiring diagram for this 2004 Yamaha 60 hp, model: 60TLRC .
Do not have power at the Brown wire (neutral safety switch) in the shift 704 remote control. Battery (Neg)has two small wires going into the boat and the (Pos) has one red stripped wire going into the boat.
JB
Re: 2004 Yamaha 60 hp, model: 60TLRC wiring diag.
That wiring diagram is present in both aftermarket and OEM Service Manuals, James.
It is not clear what your question is, but if you want someone to send you a copy of the wiring diagram that would be illegal because it is copyrighted material.
JamesMc
Hi everyone, esp. the folks who helped me with an unusual problem. As you can see by my earlier posts, I had a wiring problem. No power to the console, neutral safety switch, etc.
Strange as it may seem I had additional help from some animals. When the animals chewed on my wire harness they caused me to disconnect the engine side of the harness to ensure continunity in the wires that had been bitten. Checking all the pins against the wires I found a fault in the red wire. It wasn't the animals but the water intrusion thru a small hole in the red wire that cause enough corrsion to eat away one inch of copper inside the coating.
After a splice, the engine is back on line. Thank you again
Older, yes. Wiser, maybe.
lifeisfun
I wish everyone would post update like you did :)
