kend301
- Joined
- Jul 4, 2009
- 1,005
Re: yamaha 1200r engine failure
If I did my math right , .66mm clearance , one thousandanth of an inch is .0254 mm so .66 divided by .0254 gives you 25.98 thousandths of an inch .
WOW THAT IS LOOSE !!! I would check all cylinders and sleve the dammaged one (chip sounds big ) and get proper pistons that have about .002 to .003 thousandths of piston to wall clearance. You may need to get .020 over pistons for a kinda of close fit . To do it properly you need to get a machine shop envolved !
