MMO question
mla2ofus
Has anyone ever tried Marvel Mystery Oil mixing 25% of the 2 cycle oil like Marvel recommends??
Mike
Re: MMO question
Why? What's the stated benfit? Marvel Mystery Oil is not a TCW-3 rated oil so why use it as a 25% replacement for a "required" oil? MMO has been around for well over 50 years and at one time and it was used as an upper cylinder lubricant (meaning valve guides). It was sucked into the intake manifold from a separate container and controlled with a needle valve. How well it would lubricate a high reving two stroke is not something I would experiment with.
Frank Acampora
Re: MMO question
I did use it for a while on my small model airplane 2 cycles just to experiment, 16,000-20,000 rpm. It is a very light penetrating type oil. Smells nice in the can--that's about all I can say.
As stated in above answer, "Why use it."
What is the stated benefit? What is the cost? If stated benefits do not outweigh the added costs, what is the sense in using it?
Remember, 2 cycle outboards have been around for a long time, and most have run very happily for years on regular TCW oils. Every upscale oil or snake oil claims added engine life and other benefits. But again, do the perceived advantages actually exist and do they outweigh the costs.
Can't blame Marvel for trying to increase their market through advertising--that's the nature of business.
mla2ofus
Re: MMO question
Thanks for the info, fellas. That's why I asked.
Mike
dingbat
Re: MMO question
Where did you come up with the 25% of oil in a 2 stroke?
The only claim I see relates to a 4 stroke oil change. Nothing said about usage in a 2 stroke.
mla2ofus
Re: MMO question
Substituting 25% of two stroke oil w/MMO is what they recommend on their website.
Mike
Re: MMO question
Here is the site I visited and there is no reference, at least that I could find, about replacing 25% MMO of the two stroke oil with MMO. It does mention 1qt in a 5qt oil change on a four stroke which equates to 20%. That is reasonable. Show us the 25% you saw.
http://www.marvelmysteryoil.com/index.php/site/products/
