Grinding Noise In Outdrive
juscogens
I have an 07 Volvo Penta with composite outdrive on by 26' Four Winns, and shortly after leaving the dock yesterday, a grinding/grumbling/growling noise started coming from the outdrive area (I couldn't pinpoint the source, but it was definitely coming from the outdrive and not the engine). At first I thought it might be the gimbal bearing or u-joint, but the noise was not any more pronounced when I turned the wheel. Contrarily, when the wheel was hard to port, the noise stopped. No problems with steering or engine performance were encountered.
Is this still the gimbal bearing or u-joint or is it something more/less sinister? Any insights would be appreciated!
Don S
Re: Grinding Noise In Outdrive
Pull the drive and check the ujoint bellows for water.
Volvo has had bellows problems with that drive.
Water in the bellows = damaged gimal bearing and ujoints.
juscogens
Thanks, Don.
That's about what I figured. Do you think this will be covered by warranty? The engine is an 07 with 115 hours on it.
Don S
I don't have a clue, check with your dealer. There was a campaign by Volvo to fix a bellows problem. But it expired Nov 1 of this year.
Might have your VP dealer look at service bulletins 44-1-59, 44-1-73, and 44-1-75
