meyermarine1989
- Joined
- Nov 28, 2009
- 2
i have a 1969 50 hp mercury inline 4 that will start right up and then run wide open for about 10 minutes and then lose about 1000 rpms. when this happens i will reduce throttle back to an idle for about 15 seconds and then it will work at full rpms again. it will run again like it should for about another 10 minutes and it will do it again. when i got back to the boat launch and tried to start it again it seemed like my battery was dead. i just rewired everything and i dont know if i wired the rectifier up correctly. would that maked a difference if my battery wasn't charging. the motor has a magneto and it is driven by the flywheel. it is pumping water good and i always mix my oil 50:1 or 45:1. please help. thank you.
