1979 Johnson 70hp over-revs
Hoochie
Gday,
I've got a 1979 Johnson 70hp here, haven't yet used it in the water.
The motor reaches very high rpm when the throttle plate is only just fractionally open. If I was to go to WOT it would surely damage the engine. This is being tested in a 44 gallon drum full of water to provide some back pressure.
I have little experience with outboards, is this normal?
There does not appear to be any air leaks surrounding the carbies, timing is fine, seems to blow a fair bit of smoke, but this is only running the engine for short periods.
Cheers,
Chris.
cougar1985
Re: 1979 Johnson 70hp over-revs
do you have a prop on ?just puttin my motors in gear in a barrel they become the worlds deadliest washing machine,lol.you cannot run a motor properly in a barrel, you need a test tank to go into higher revs and preferably a test wheel.the prop is what gives you a load,without it your asking for trouble.
Hoochie
No worries, time to put her on the water then.
