1997 25hp carb kit question
salvo
Hi,
Have 1997 25hp mercury outboard S# OG459142 (1025201TD)
Smart enough to know the carb needs a rebuild due to varnished up interior
Smart enough to have purchased Seloc manual
Smart enough to rebuild carb
NOT smart enough to determine which carb it is and what kit to buy
says WMC on carb, spent a lot of quality time searching the internet for a solution and am finally bothering you folks...
any actionable intelligence?
thanks
salvo
Re: 1997 25hp carb kit question
sorry,
clearly did not understand the layout here...
thank you for your help...
will941s
The same carb kit fits the 15-25 hp. The only difference in the carb is the jet, which you won't replace with a standard rebuild kit. So in theory there are no kits for the 25 alone, they fit all the models in that range.
