1999 yamaha f40
merk76
I have a 1999 yamaha 40 4-stroke. This motor starts runs idles fine, but will make a ticking noise could it be a valve or rod? Any help thanks.
Zjb187
Re: 1999 yamaha f40
I've got the post right above yours with the same exact problem .. Seems noone really knows since neither of us have a reply
99yam40
Re: 1999 yamaha f40
I have read that some motors will make a ticking or tapping noise if the fuel pump is not completely full (system sucking air into pump), but I have no idea if that is true on your motor
Re: 1999 yamaha f40
If the noise was a rod or main bearing it would be a rather dull metallic rap and not a ticking noise deep in the engine (the front end of the engine). That would very likely be followed by a low oil pressure alarm which you apparently are not experiencing. A ticking noise may indicate it's time for valve adjustment and would be heard in the cam cover area of the engine (the rear end of the engine). Where that noise is coming from would help has determine what the issue is (if there is one).
