Biscayne Bay
- Joined
- Nov 30, 2009
- 3
I have twin 200 Yamahas (carb. salt water series). The R engine oil tank does not fill to the full line, and eventually I get all the alarms, reduced RPMs, etc., when the oil reaches the bottom line on the tank. But using the manual switch does pump oil in to the tank. I have tried to solve this problem without success. On the R remote tank: I changed the filter, the sensor, and the pump. Problem not fixed. I then changed the sensor on the R engine tank (all new parts). Problem not fixed. Then I emptied the L & R engine oil tanks, and swapped the oil sensors knowing the L engine system was working fine. I turned the keys on for both engines, and the L engine tank was pumped to full, while the R engine tank stopped midway between the full and low marks/lines. I then used the switch to manually pump the R tank to full, and then drove the boat. I found the oil in the R engine tank was still not getting pumped to the R engine tank when the oil level went below the full mark. Manual pumping still works. Any help would be most appreciated.
