Jump out of forward
mstrobeck
I have a 1997 25hp 2 stroke Johnson I went out put it in forward put it under load at about 4000 rpm went about 500 yards and it jump out of gear.
pulled it back to neutral to stop the engine from revving looked at shift cable and everthing looks fine no problem with reverse, I put it back in gear it did the same thing. I tried to manually put it in gear and sounded like gears grinding. Any ideas?
wilde1j
Re: Jump out of forward
Likely fwd gear and clutch dog are worn and need replacement.
jasper60103
Was the lower unit recently removed?
Also, welcome aboard!
tx1961whaler
First thing to try is disconnecting the shift cable and shift the motor by hand with the cable disconnected. If it works manually, then the problem is with the shift cable or cable adjustment
mstrobeck
No the lower unit has not beeen serviced in three year as I only put about 15 hours a year ont it. I use my electric trolling motor the most.
Thanks,
mstrobeck
Yea I thought about trying that but didn't have my flush kit with me. I will try next weekend.
Thanks
Rudi2
Thanks,
Well, you really should be changing that oil at least once a year no matter how many hours you put on it. The condition of that oil will tell you alot about the condition of the lower unit.
Let's hope it's the cable.
