PLEASE HELP!! Evinrude 50hp Tilt/Trim Issue
Nismospeed
Ok, to start off, we have a 1990 50hp Evinrude VRO. Model No, VE50BELESR, with a manual assist tilt/trim pump (img 1). I think thats what it is called. Anyway, next to the motor is a little latch that shows an image of the motor up, and one of the motor down (img 2). Attached to this latch is a cable that runs down the mounting plate and threads into the hydraulic pump. The threads are stripped and torn beyond repair (img 3), and there is fluid leaking out of the top. As it stands, it is usable as is, you just have to strap the motor to the mounting plate so it doesnt bounce. Then in tow, I strap it to a transom saver and its fine (img 4). I just have to grab the motor by hand to raise and lower the unit when I go into or come out of the water. However... when I lower it for use, the prop still points about 15-20 degrees up and I cant plane out (img 5). I just bought this and this is my first experience with this type of tilt/trim unit. Can I replace the threaded insert? Where can I find a new cable? How can I get the cylinder to lower even further so that I can plane out on the water until I can replace this stuff? And does anyone have a rough estimate? I thought about going electric, but wow...not for over $800!!!
hopscotch840
Re: PLEASE HELP!! Evinrude 50hp Tilt/Trim Issue
The tilt/assist unit is toast. They are not repairable. They run something like $400.00 plus the cost of the cable. Watch E-Bay for a replacement (used) for around $150.00 or a used power tilt/trim for around 400.00. Neither option is good.
Nismospeed
Thanks for the info. I started taking the unit off the boat, i got the cylinder disconnected from the motor itself, but I forgot to take the mounting brackets off to pull the bolts out of the bottom. looks like i have some work cut out for me. thanks hopscotch!!
Nismospeed
ezeke, thats disgusting... the dixiemarine image is a dead on match to what i need, and that little price tag is just gross. crap... oh well, at least i have some time to pull the money together for it before the season. if i am lucky, i might find a craigslist listing for an electric for the same price before then. LoL....yeah right.
