Re: 1989 Wellcraft Monte Carlo ?'s and build
Well I picked up an anchor today.... 13 lb plow $38 new.....
still need a windlass
I made yet another adjustment on the plumbing. I shortened a line a few inches and routed it slightly differently so that my lines would lay better (yeah I'm picky that way) It doesn't work any differently at all but looks better
I also (choke cough) drilled a hole for an overboard fitting to drain the pop off of the water heater overboard 6" above the water level... I used a fuel tank vent fitting so that if the valve trips it doesn't project outward... Hopefully there will be less chance of scalding swimmers that way.
I also routed a new 1/2 very heavy wall fuel hose for the fresh water intake of the genny.... the old one was 3/4" and this hose is nearly the same diameter. I found an fitting for the 3/4" inlet with a 1/2" hose barb.
I also put in one of the trim pumps and 4 batteries 3 group 31 general purpose house batteries and one group 27 marine starting
I am trying now to decide how I want to wire the charging system.... I believe I may charge the 31's with the main engines and also start from them. If so then the genny will have it's own battery which will double as emergency backup for the mains... Or for that matter starting the genny either by battery or rope will charge all batts
I will be taking my fairing block to the belt sander tomarrow to change to match my deadrise angle and mount my transducer in the last open hole
I got the last of my thru hulls today to plug the transducer holes in the bottom but the genny mounts didn't show.... I'll likely put one of the engines in and wait for the second untill the genny is mounted.
