Evinrude 35 lots of blue smoke and some white? bad idle
steelespike
Re: Evinrude 35 lots of blue smoke and some white?
Sure looks like steam it disapates too fast for oil smoke.Observe the plugs when you pull them.Look for rust,water droplets or super clean.
kenmyfam
Just checked the link out. Looks like steam to me.
flatsfishing
Does anyone know the Torque specs on the head bolts?
bktheking
18-20 ft lbs
oceansbreeze
it's simple posts like this thread that make this community so great to me. somewhat straightforward problem..... original posted providing all info, and following through - great replies full of knowledge and experience... and nic to learn some stuff as we read...
Hope the retorquing and plugs fix ya up! :)
flatsfishing
I have been messing with it today and it just seems like its running really rich... I tried messsing with the idle screw but didnt seem to help. Also when I do the compression test it seems to be getting a lot(soaked) of fuel on the tip of the compression tester..
does anyone know how to adjust the carb?
kenmyfam
You get the next one!
It was funny !!! I had the exact same attachment ready to post and checked back before i hit the post button and there it was !!!
Don't matter who gets it as long as it is there.
Good work my friend.
bktheking
2 things, just going back to your video, I don't know if that motor is idling, seems to be running between 1500-2000rpm and if it is, you can adjust the idle until the cows come home and it won't have an effect. 2nd, that is steam by the looks of it and going by the bucking and sudden stoppage of that motor me thinks you are getting water on the plugs, water and spark don't mix. Personally I wouldn't run that motor anymore unless you could be absolutely certain that the head/head gasket are tip top :D
If the carb has never been serviced it may be a good idea as part of this exercise.
To me this is idling
http://www.youtube.com/watch?v=cJKZd9wZqrQ
coolguy147
guess i should post in here:eek:
your first the idle is way to high!!!!:eek:
2nd video sounds just about right. thats how my little 10hp sounds.
clean the carb. clean carb= effecient burning=maybe less smoke. but it just looks like steam
change impeller havent done so in a while.( 1-3 years) if you dont remember or dont know do so anyways.
dont i mean dont shift gears until you fix your idle problem:eek: have changed gears at that idle before?:confused:
for compression i suggest a decarb. if numbers dont come to normal look into headgasket. get the right spark plugs!:eek: get new champion plugs gap at the gap they told you:cool:
coolguy147
also another note to add.
is the motor hard to start?:confused:
flatsfishing
It fires up quickly stalls a few times usually untill it warms up then idles fine (usually). When I rev it it smokes a lot and is slow to rev when I checked the plugs later today they were black so I know its just running way to rich. I will probably post another vid tomorrow from the cold start up.
Where can I find which plugs It uses? Right now it has the NGk-BZ7hs and I googled it to see which ones I need and Champion QL77JC4P came up are these the right ones?
Thanks a lot guys,
Dan
bktheking
Thanks a lot guys,
Dan
Champion Marine plug L77JC4 gapped to .030
Running rich if it indeed is will require a carb cleaning and a kit if the plugs don't help it run better, plugs don't usually cure a rich condition but try the cheapest route first.
coolguy147
also another thing to add is make sure you set your carb needles correctly.
AFTER you clean the carbs:D
50:1 mix tcw-3 marine outboard oil.
my 1958 35hp smokes a lot too. not so much at low speed but i still does. when i rev it up boy it looks like a bonfire. especially if i holeshot it. then it leaves a sheen of blue smoke behind me
kenmyfam
I'm still thinking steam on that video you posted.
coolguy147
im thinking steam too. thats quite a bit of steam more than mine though.
looks like steam also, exhaust gasket, water mixing too far up in the block. watch the pulse.
coolguy147
Re: Evinrude 35 lots of blue smoke and some white? bad idle
i really feel that the steam problem isnt really worth fussing over since cold start it will smoke and steam. even the dfi have a tiny bit of blue smoke on start up cold just sometimes not noticable
ok im am very positive that you will need a carb cleaning and rebuild in order. it should be lean sneezing like that like especially at those speeds. about the carb start up you bring warm up lever all the way until stop. then turn key with choke until start may need a few bumps of choke but i dont think that engine will depends on climate i believe. and every engine is different.
then after use seafoam since it will be used to its fullest and wont have really hard time of it stalling. easier to decarb.
