intrepidvoyager
- Joined
- Mar 24, 2009
- 216
SX drive which won't come off ..rust on the drive shaft .....fortunately the engine is not in the boat ...however no amount of penetrating oil shot into the bearing past the seal from inside the boat or pulling the leg with a truck or pounding on the drive shaft will budge it more than 1/4 inch. ........SO what I am thinking now is to get a one foot length of steel pipe that will fit over the drive shaft and a massive sledge and try to pound the gimbal bearing out ...So my question is what diameter should the pipe be either inside or outside ..... inside I guess is just larger than the drive shaft diameter but might be better to try to hit the outside ring of the bearing but cant see past the seal ....So am wondering if anyone has done this before. Don't want to damage the gimbal housing assembly. Corrosion is a massive problem here in Hawaii......
Thanks
Thanks
