fastaction
- Joined
- Dec 7, 2009
- 9
OK Long story short 93 bayliner 26ft trophy twin 120 force Was sitting for 5 years and I got it for free.....
As I was leave with the boat ,the guy said something about the Buzzer going off and bye...
Well new parts
Flushed fuel tank
New fuel filter
Comp check 125 on all 4 x 2 =8
clean carbs with new kits
new Water pump kits
New thermostatas
Lower gear oil
New plugs 8
2 new coils
So any way With the New pump kits in and New thermosatats .The buzzer goes off in about 10 mins of running on 1 motor . I checked the temp of water coming out and it 168 and the Block is 180 Now the thermos i put in are 130 So ,I dont understand why It is overheating ..
Head gasket ? If so Wouldnt it effect the running of the motor?
Temp swicth ? Is there a test ?
Can you Run or make you own Tell /tale water pisser line ?
I see smoke But oil mix /steam
Well new parts
Flushed fuel tank
New fuel filter
new Water pump kits
New thermostatas
Lower gear oil
New plugs 8
2 new coils
