Re: 2007 Toyota Tacoma w/Bad Rear Brakes
no way ,no how...the pads , or wiping the smirk....I have installed new pads on more vehicles than I can remember this month alone, to believe you got 115,000 out of a set..........
time to get out my chest waders it looks like.....
It's a fact and if you want to call me a liar on this board in front of everyone, so be it, but you are dead wrong.
I am right, you are wrong, end of story.
"GM had a similar problem in the late 80's and early 90's. The rear disk brake setup on the midsize cars required using the parking brake to adjust them. SInce nobody did the brake slides would rust up and the rears would stop working altogether."
Yes, absolutely true. Had a 1990 Lumina that wore out front pads in 19k. Started using the parking brake, and the pads lasted 30k the next time.
That system has been completely changed, and the parking brake no longer adjusts the rear brakes. As a matter of fact, the rear parking brake is now a small drum brake system that works against the inside of the disc brake rotor hub. I know Stachi will say that's impossible, but that's how it works.
