deuceswild123
- Joined
- Nov 2, 2009
- 3
I have recently purchased a 1982 Cajun fishing boat. this boat came with a 12-24 volt trolling motor. the problem that i am having is the boat in its past was hard wired to only run 12 volts. all of the original wires are still run to the front of the boat but they bypass the selector switch and the battery indicator lights. what is the correct way to reconnect these components so that i can select between 12 and 24 volts. if it helps there are four wires leaving the battery area going to the front of the boat.
