Assembly of Seirra marine coil
rkmnoles
Let me preface this post with I'm an idiot. I received new coils for a 150 Evinrude 79-84 and I can't figure the way to assemble them. Coil, wire, boots and what looks to be spring connectors are all separate. The spring connectors are what is puzzling me . HELP!!!
mikesea
Re: Assembly of Seirra marine coil
I think your talking about the connector for the parkplug wire,you crimp the sharp point into the plugwire so it makes contact with the inner wire,then ,get a bit of dielectric grease,and lube it up so it will then slide into the plug boot,push into the small hole side far enough that the plug top will slide into the spring looking connector you installed on the wire,be sure you put all the small wires in proper order ,or you will get a mis fire
i have learned to strip back some insulation and wrap it around the spring before inserting the pin into the wire. this assures contact. don't depend on the pin.
rkmnoles
Thanks for the reply , I will see if I can handle that. Thanks again.
