12V automatic air pump for inflatables
TonyV
Hello
Could anybody recommend a good 12V air pump for inflatables with automatic pressure regulator and power cut off that would be able to inflate high pressure air floor (up to 11-12 PSI)?
Thanks.
jspringator
Re: 12V automatic air pump for inflatables
Spring a little extra cash for the Bravo unit with the battery.
Once agin I recommend the http://www.defender.com/product.jsp?path=-1|294|88529|320520&id=88624 if you have the cash. It has an HP/LP mode and can be set for variable pressures. You might find it cheaper on the net, but at least the idea is there
I had one of these for my 16' Zepplin rib., It was a great thing to have on board but one of my storage lockers leaked and a week later it started giving me problems. West Marine replaced it at no charge because I was within 90 days of purchased, I sold the replacement with the boat after a year of use.
I assure you it will firm up the floor more than adequately.
