WestBoundFishSociety
- Joined
- Dec 11, 2009
- 6
My FICHT has been good, almost too good to say the least. It has gotten me there and back including 90+nm round trips. I keep regular logs and keep to my maintenance schedule. The engine has 690hrs on it, 50% below 1000 rpm's and 18% >5000rpm (cruising). I normally get 3.0nm/gallon of mid-grade or better, per trip no matter how I use the throttle. I am also using Evinrude HD-50 oil only, every time, and I flush it out with fresh water for 5-10 minutes after every trip (saltwater only).
The last two trips have resulted in less than 1.5 nm/gal with no signs (or very little) of trouble. I did notice that my top end speed was down, from 38nm/hr to 32nm/hr. I de-carbed, changed all fuel filters, ran diag software which yielded NO error codes, etc. Here's what I have found: !) fouled plugs - starboard side only, changed. 2) Fuel Pump Pressure = 35psi for 10 secs and then down to 10psi 10secs later - any thoughts? 3) When firing the fuel injectors using the software, injectors 1,2,3,4,6 are distinctly loud whereas #5 is muffled. 4) Loading of all cylinders yields the expected result as does removing spark plug leads.
I have flushed the fuel system w/ "Seafoam" which has allowed fuel injector #5 to sound off a bit more but not equal to the others as of yet. And yes, the s.plugs are indexed. And there is still an amount of carbon flowing from the exhaust while still on the trailer. I know I need to run it WOT on the water to shake the rest of it free.
Any ideas to as why a good running/sounding engine would lose half it's fuel efficiency? What does the fuel pressure and the F.I. tell you? If it's the fuel injector, how do you test it to make sure before sending it off?
