Life-time impellers? Time for a change?
sentinel
Doing a little musing with the Area 5150 Scientists in captivity underground here.
We think that it is possible to design a life-time lasting housing and impeller which can be installed above the foot within the spacious area of the lower housing.
Water does not compress so it would need careful engineering on water volume vs shaft RPM for low through high speed operation.
The principle in a nut shell is the INCLINED PLANE. This is a (VERY) powerful means of forcing water upward and into an engine block. The single blade would be metal with a very slight minus tolerance inside the housing. The blade shape would be similar or emulate a wide diameter screw thread. The degree of pitch would determine volume of water vs RPM. Water entry would be underneath the blade and water exit would be in a cavity above the blade and pass into the standard tubing within the housing. The slight minus tolerance would allow for some pressure relief at higher RPM's.
Something along those lines...... I have not spent more than 15 minutes on this (mostly typing), so there might be something I have overlooked or could be added.
Addendum - On (all) existing motors, the lower water pump base and drive shaft w/key would remain the same. If manufacturers were willing.... an add-on upper water pump housing which would be a little taller, and the spiral impeller with possibly a vertical water ducting interface COULD be offered as a kit. This would allow for a quick retrofit by the user. The loss in moneys for Service centers and rubber impeller manufacturers would be enormous however......
Sentinel.
(Our Scientists were forced to return into cavern with a bull whip.):cool:
Frank Acampora
Re: Life-time impellers? Time for a change?
Ever hear of the KISS priciple? Keep It Simple, Stupid?
There is a sound engineering reason why all outboard engine manufacturers use a rubber impeller water pump. It is simply the best design for this application.
Keeping the existing housing and replacing the rubber impeller with a sliding vane pump impeller (more money so manufacturers would not use it) will result in a quite acceptable lifetime water pump.
Only problem is a sliding vane type will not go centrifugal at higher speeds as a rubber impeller will.
sentinel
The necessity "to go centrifugal" is an effect of rubber vaned impellers because they transfer small amounts of water(between the vanes), from the intake port cavity to the output cavity and into the the water tubing. At high RPM's the vanes bend because the transfer cannot take place fast enough and water does not compress. The bent vanes create a drag causing the water to move.
This is hardly a KISS principle. More like a substitute for KISS.
The inclined plane, works well for boat Props, Turbo charging, Jetting, and a host of other applications because it IS founded on solid KISS & physics principles. Just like a post hole digger or aircraft propellar......One piece with continuous volume transfer without interruption as long as it is rotating.
So which is more KISS-able? :rolleyes:
Sentinel
