77_starcraft
- Joined
- Oct 8, 2007
- 55
After reading several methods of winterizing I drained the block and refilled with red RV anti freeze thru the thermostat housing. I also filled the fuel/oil cooler hoses and put a quart or so into each hoses leading to the exhaust manifolds.
didn't see any make it out the exhaust tips and wondered if the anti freeze filled and exhaust port or cylinder as the engine is not running...
Is this possible or does the water have to exit the exhaust tubing?
How much water do the exhaust manifold hold before they spill into the engine or out the tubing?
I started and ran the engine for a minute or two on the muffs just to make sure I don't end up with a rusty valve or cylinder.
1998 Baja 232 Islander
454MPI / Bravo 1
454MPI / Bravo 1
