natemoore
Thread starter- Joined
- Jun 13, 2009
- 844
Tomorrow I'm going under the knife to get hip resurfacing (the Birmingham Hip) on my left hip. One of the things I wanted to do before being laid up for a few weeks was get my boat motor running after a summer/fall-long complete rebuild.
Well......a few minutes after startup--after verifying good oil pressure--I heard a brief, metallic clankity-clank.
When I took off the valve cover, I saw to my disappointment that the #1 intake (?) valve (the second one back) was bent and out from under the rocker arm.
I think the clank I heard was the camshaft slapping the bottom of the lifter or the push rod bouncing off the valve cover. I hope that the oil pressure kept the lifter up off the camshaft because I do not want to have to pull all that crap off again, although I think I can remove the lifter cover without removing the intake manifold.
I scrupulously followed the instructions in the manual concerning adjusting valve clearances, torquing the rocker arm bolts, etc. In fact, I probably quadruple-checked all my procedures, clearances, and torques, so I'm clueless as to what caused the pushrod to bend like a banana.
I rolled all the push rods on a piece of glass to check their straightness. All my clearances were all on the low end of the .110"-.210" range. I did have to buy a couple of Ford pushrods that were shorter than the shortest ones offered by Mercruiser to achieve the correct clearances....but of course I threw away the scrap of paper that had all that information, so I don't know if the bent pushrod was a Ford, a Mercruiser, or an original one.
Also, I primed the engine with a drill with the valve cover removed to confirm that oil was coming out of the top of each pushrod.
Any ideas?
On the bright side: no oil leaks and my trim indicator works!
Any ideas?
