Re: 1966 Evinrude 60 hp shifter stuck
Mmmmmmmmm rusty water.....the best thing there is to spoil a boater's day. I bought a motor like this once and yes, it did end up being junk, from the powerhead gasket, down. It was a 1968 Evinrude 40hp. The guy let it sit for years while the lower unit was completely rusty inside. Luckily, I was able to use the powerhead on a 1959 35hp and made it an awesome motor.
On the other hand, your lower unit could be burnt up/siezed up from lack of oil and that is almost as ugly of a scenario. That motor will have the same lower unit as several other models in those years too. If it has a split gearcase, then it's the type I. If it doesn't have the split gearcase, then it's the type II. If you let us know, then we can let you know what other lower units are compatable with your motor.
Before you go through the expense of replacing, or rebuilding the lower unit, I would check over the power head and see if it is in good enough condition, to make it worth the time and expense. Make sure the compression is good on all 4 and see what condition the carbs and ignition system are in.
