i have a question about bilge pumps again. So to get a good bilge pump system i need a pump, a float switch, and a 3-way switch? Am i right? correct me if im wrong. I already have the pump, so what else do i really need?. Can anyone give me a diagram on how to hook them together? Like a wiring schematics.
And lets say i want to install a back-up bilge pump, how would i do that? Do i have to wire it separately? like different wires, different float switch, and the hose where the pump suppose to pump the water out in a different place?
Or if i does, does the back up pump have to connect straight to the primary? Im so confused on how to hook up a back up pump!!
I need some one to help make a diagram or some where i can visualize this.( like after hooking the primary then to add the back-up what do i have to do next)
When the back-up pump is done and primary one too,doesnt draw a lot of power from the battery? How do you know if you hook up all the wiring properly like when i turn the engine or motor off and the pump should still be running. How would you test that. Im sorry for asking too much questions
because if i dont i wont get it done by wednesday to try this boat at the lake. Im such a noob at this.
