I have a 97 Edgewater 205CC with a Garmin GPS Map 398. The transducer mount keeps coming loose during operation making my depth finder inoperable. The transducer is mounted in the inset area of the transom. In otherwords there is an indent in the hull to allow for the outboard as opposed to the hull and transom being straight. The only thing I can surmise is that when coming off plane the water pressure in the inset area is strong enough to loosen the mount. I have tightened the mount repeatedly only to have it happen again. Has anyone else had this problem? Can I resolve it without changing the mount location, possibly with rubber washers?
