Re: Charging Batteries with a generator
I ran my house on a Porter Cable generator for several weeks after Hurricane Katrina. I did ground it and always ground a generator when I can.
I also recharged batteries every day with it and had no problems. One thing that people don't realize, is that the power that you get from "the pole," isn't as "clean" as you think it is. On top of that, any circuit that you have in your house that has something like a large air conditioner or freezer compressor on it, can cause "drops and spikes."
If you have a decent quality generator that runs at the proper rpm and maintains that consistently, you should be getting pretty decent power. If you have a Honda generator, or any other generator with electronic control, you should be gettiing a "pure sine wave" and its probably as good or better than what you get from a circuit in your house, anyway.
One recomendation that I make for both generator use and in home use, is an Acoustic Research power strip. I don't work for them or sell them, so this isn't spam in disguise. The reason why I make the recommedation is because I use a model that they make, that is rated at 5,100 joules. To put that in perspective, the average power strip with surge suppresion is rated at about 600 to 800 joules. One of my ARs once saved about $1,500 worth of computer monitors and other gear, when my house was hit by lightening. I ended up wishing that the actual computer was running through it too!
