What is the model of this boat?
ozenine
Hello,
I hope everyone had a great Christmas and looking forward to more days off ;)
I came across this ad on the local site. Not that I was lookign for glass boat, but the condition is pretty good and owner claims "no rotten wood". However, the owner said that the hull is rated up to 45 hp, but the engine is 90! :eek: I do not know the model of the boat, but I thought that somebody here might. Here is the ad:
http://toronto.kijiji.ca/c-cars-vehicles-boats-watercraft-powerboats-motorboats-power-boat-W0QQAdIdZ176511211
ezmobee
Re: What is the model of this boat?
Who cares! for $2500 canadian....go buy it! It does not say in the ad the hull is only rated to 45HP or did you talk to the owner? I would find it very hard to believe that hull is only rated for 45.
ozenine
thanks, EZ!
Yep, emailed the owner and he said that the hull is solid and transom is good, no rotten wood and the hull is rated for 45 but he had 90 on it and it was great running even in rough water with this motor.
I care about safety - do not really want the motor to run away with part of transom in the middle of the lake ;)
ezmobee
Well it looks to be about a 16'. No way it's only rated to 45. He must be mixing numbers up somewhere. With the interior in that good of condition I wouldn't be overly suspicious of rot. If there is anything screwed or bolted to the transom you may want to check around those areas but it sure looks cherry to me.
