Boston Whaler(?) ID help please
rebars1
I had posted this in the "Whaler" forum with no response, so I am submitting it here also.
I have had this boat for about two years now. It is 18' long and has "Boston Whaler" logos on the sides. The CA registration lists it as a 1976 Boston Whaler. It has a foam filled double hull, however, the shape of the front flares and the finish is different than other Whalers I have seen. The transom has "18UB7632" cast into the stern face. It has a heavy steel or aluminum rim/rub rail all around the top edge of the hull. Any ideas? Boston Barge?
jay_merrill
Re: Boston Whaler(?) ID help please
I don't think its a Whaler. It looks like someone's attempt to copy the old Whaler Montauk. Also, if I remember correctly, the first three characters of a Whaler HIN should be "BWW."
rebars1
I do not think it a Whaler, too. Unless it was an experimental model.
In 1975 I had a small Sunflower sail boat that was of similar construction and finish texture. Maybe the same company made this.
Here is the end view of the flare:
slasmith1
no manufacturer data comes up with that hin maybe you mis read it if you check again and re post the first three digits of the hin I will re check it for you
JB
Not a real Whaler in my opinion. Too many features BW never used.
rebars1
Thanks for checking, slasmith and JB. It is the correct hull number...you can just make it out in one of the pictures. I could not get any MFR's info from it online, either.
I thought it might have been a BW "work boat", or something.
The next question, then, is if/when I sell it, do I advertise it as a BW (as it is on the reg papers) or a "BW clone"? Apparently, at some point in its history it was labelled and registered as a BW.
ezmobee
BW aficionados will probably come out of the woodwork to yell at you if you did :rolleyes:
markernineteen
Whaler or not that's still a very interesting boat . I've seen similar hull markings on boats used by the navy , lifeboats , workboats etc. By the way I've owned Whalers for twenty-five years and I think you can call your boat whatever you want !
Philster
Could 18U at the beginning of the HID be something like IBU? Are you getting the first part right?
For example, if it is something like IBU, that would be Islander Boat Works. I am not saying that this is it, but I can see how it is possible to get something like an I and a B confused for 18 on a stamped I.D.
rebars1
The letters are about 3" high, so they are easy to read.
Markernineteen might be onto something: I bought the boat from a navy man at a base in San Diego. 18UB 7632= 18' Utility Boat, 1976, #32?
Philster
Naval Utility Boat. Many are of the Boston Whaler Type.
Newer ones can be seen pictured here:
http://www.hazegray.org/worldnav/usa/guard.htm
Search page for "Boston Whaler".
Similarities in the stern/transom, maybe because they tend to use dual engines in the Coast Guard and Navy apps.
Home Cookin'
looks like it was outfittd for industrial use; I see that a lot around our harbor.
Whoever painted it white probably added the decal (Navy would be gray).
The hull ID could be an added serial number by the original owner, whether navy or civilian, and not a manufacturer's hull number.
rebars1
Thanks for the info guys. It is a pretty solid feeling boat (read industrial work boat), especially with the thick aluminum angle bolted around the rim. It is definitely not a delicate creature. If anyone sees one like it please post a picture for me.
The old 60hp Johnson used to over heat easily until I did the reroute of the tell-tale nipple to the top of the block. (advised from this site).
Any name suggestions?
jay_merrill
I would advertise it as a trihull and not worry about the registration. If anyone asks, I would just let them know that the registration info is as when you bought it.
While I still don't think it was manufactured by BW, the ex-military theory makes some sense.
rebars1
Good ideas and advice concerning my mystery boat. Thanks for the input.
rebars1
I can buy the "military utility boat" idea. But I kinda hafta agree with jay merill (not by BW) that although there are similarities, it just does not have the crispness or lines as a BW.
Unless it is a BW experimental protoype.......
In either case, it does work well as an sturdy, unsinkable chunk of foam for my teenaged son to use.
