External Voltage Regulator
full stringer
:confused:I have an 1984 omc sterndrive 5.7 litre gm and on the port side of boat on the floor in the engine compartment is what appears to be a volt regulator if i hook up a two battery charger bank and i have an alternator w/ an internal regulator does the external regulator still need be how should i proceed
Don S
Re: External Voltage Regulator
I would say you need to post a picture if it. Can't answer your question if we aren't absolutely sure if it's a regulator or not.
full stringer
you got it i sure will get a pic however i remember a sticker saying surge interupter and the box has a 4 ga wire connecting from alternator alt and a black ground 4 ga wire to alt bracket other wires go out for accessories i think
Alpheus
Its a surge protector that smooths out the voltage from your alternator and protects your electronics from an alternator failure or voltage spike...
Don S
How can you be sure of that? Do you know something the rest of us don't know, or is this going to be a guessing game of "What's in my bilge" ?
It could also be an old Loran capacitor setup to stop the noise from the alternator, or an isolator, or ..................
Alpheus
OK let me rephrase. It could be a surge protector that smooths out the voltage from your alternator and protects your electronics from an alternator failure or voltage spike...
Don S
Yes, it could be a surge protector, never seen one on a boat, but OK.
That is why I just ask the original posters for pictures, or a better discription of what they are looking for, instead of just guessing.
So many times, posters ask a question and just pick an answer that sounds good to them, and run with it. But it may not be anywhere close to the right answer.
Alpheus
I have one on my boat but its not in the bilge area, its installed behind my circuit breaker panel. I thought it was a surge protector for the AC side but its connected between the AC converter and the DC accessories...
