triplehooked
Thread starter- Joined
- Dec 28, 2009
- 30
I am the proud owner of a 91 Bayliner Capri 1650 with a 120 hp force and the ever so loved L drive! Sorry for the sarcasm, just found out today that these aren't the most desirable units...... Anyways, the boat is in great shape, it has one small tear in a seam on the driver's side seat, other wise it's pretty sharp. It came with two tubes, a set of skis, two props, 10 life jackets, anti-mussel coating on the bottom, a brand new battery, two covers, and a bimini top. I traded an old dodge truck for it btw. The engine was rebuilt last winter "with receipts" and it has been stored inside up until I rec'd it two days ago. I winterized it as soon as I could. The engine has been fogged, I removed the four freeze plugs from the manifold with no water to be seen, linkages are lubed, the lower unit oil is like new "no water or metal in it" so I didn't change it, gas tank treated, and battery removed. Being new to this stuff is there anything else that I should address? The owner said there is no need to flush this motor with antifreeze as it all drains out when out of the water. True? Any concerns with the L-drive that I should look out for or give special attention to. And what makes these so terrible? Also, it says on the title 1650 with matching #'s to the boat, but the boat is 19', is this a typo? Long winded but I want to know all I can. My next step is finding a service manual.....Any and all info. is appreciated..
