Need Video Card for Emachines T2792 to support Windows 7
Big Bubba
Hello to everyone,
I just installed Windows 7 on my older daughters Emachine model# T2792 which took really good except the on-board video card doesn't support the 32 bit version Windows 7. When I go to the troubleshoot section on Windows 7 it says I need to upgrade my display adapter/video card to Direct X, 9.0 or better. There is so many video cards out there I am not sure which one to purchase that will be compatible with my Emachines T2792 and will work with Windows 7. Can you experts out there recommend a video card/display adapter to purchase? Thanks for your help, Bob.
Big Bubba
Re: Need Video Card for Emachines T2792 to support Windows 7
Which one do I download? Can you provide the exact direct link that would work with my older Emachines T2792 computer?
Big Bubba
I have just a basic VGA card inside of it that is integrated in with the mother board. It has the original Emachines mother board in it. I believe it is an Imperial Mother baord.
Big Bubba
Do,
I have upgraded my RAM to 1 GB so that should suffice to run Windows 7, 32 bit. It is just I habe 64MB of shared video that is integrated with the motherboard that is the issue. I did see this Video Card I think is compatible with my Emachines just not sure about the Windows 7. What do you think? See video card below.
HIS Radeon 9250 / 256MB DDR / PCI / DVI / VGA / TV Out / Video Card
Big Bubba
Can someone help me out with my computer issue?
j_martin
Have you tried to download and install directx 9?. If yer adapter runs it, yer good to go. If not, you will have to download it anyway, so you don't even lose the download time.
Just about any modern video card will work. You have to get one that fits the video interface slot in the mother board, or if it doesn't have one, one of the buss interface slots. You determine which and what by reading the technical specs for the mother board.
hope it helps
John
j_martin
I just looked up yer machine. The Intel 82845G graphics controller on that mainboard is direct x compatible. Just download directx 9 and install it.
Just about any graphics intensive program, like a drafting program, or many game programs will want the latest directx driver. I've not seen a pentium class machine fail to install it.
hope it helps
john
a70eliminator
I have an E-Machine computer that a friend diagnosed of having a bad graphics card, he brought graphics card over to my house only to find out the E-machines card plugs in different. Not that it helps you just an FYI. It was always a good computer but I accidently plugged the wrong power supply to something I forget what is was anyhow it cooked the graphics card.
j_martin
Just for your info, the graphics adapter in this machine is built into the CPU controller chipset by Intel. Intel is the site that said it's compatible with directx all versions.
Tail_Gunner
http://www.emachines.com/support/product_support.html?cat=Desktops&subcat=T Series&model=T2792
Intel? Celeron? 2.70GHz Processor
128KB L2 cache & 400MHz FSBOperating System : Genuine Microsoft? Windows? XP HomeChipset : Intel? 845GV chipsetMemory : 256MB DDR (PC 2100)Hard Drive : 80GB HDDOptical Drive : 48x Max. CD-RW/DVD Combo Drive; 3.5" 1.44MB FDDVideo : Intel? Extreme Graphics 3D
64MB Shared memorySound : AC '97 AudioNetwork : 10/100Mbps built-in EthernetModem : 56K ITU v.92-ready Fax/ModemPeripherals : Standard Multimedia Keyboard, 2-Button Wheel Mouse, Standard Stereo SpeakersPorts/Other : 6 USB 2.0 ports (2 on front), 1 Serial, 1 Parallel, 2 PS/2, Audio-In & OutDimensions : 7.25"W x 14.125"H x 16"D
You do not have a agp or pci slot for a uprgrade
I maybe wrong here but i dont believe so...Heres a tech support link
https://support.gateway.com/Support/copilot/en/us/chat_us_em_tech.asp
But i do believe 7 has a XP mode which should work well Good luck
Heres some help
http://windows.microsoft.com/en-US/windows/downloads/upgrade-advisor
Gary H NC
Go to the Emachine support page.
Search for the chipset drivers then update them.
Then try the Direct X download.
It may be the older chipset firmware that won't except that verion of direct X.
Just a thought...:)
I think Tail Gunner has the best info...just an older machine and the motherboard won't accept the newer graphics cards.It just has the onboard graphics.
I was doing some reading on Windows 7 and they say 4 gigs of ram is suggested.
I thought 7 was a cleaner operating system...:confused:
solar7647
Download the latest version of DX, if that dosnt work i would recomend a new computer that already has Windows 7. The graphic card upgrade is about $60 and you will most likly have issues with it. I am pretty into computers and e-machines dont take upgrades very well since they are so intergrated, you can get a new emachine with windows 7 for $300-$400.
Good luck, things never seem to go right with computers when you want them to!:D
solar7647
"If you want to run Windows 7 on your PC, here's what it takes:
1 gigahertz (GHz) or faster 32-bit (x86) or 64-bit (x64) processor
1 gigabyte (GB) RAM (32-bit) or 2 GB RAM (64-bit)
16 GB available hard disk space (32-bit) or 20 GB (64-bit)
DirectX 9 graphics device with WDDM 1.0 or higher driver"
got this streight from windows site, rule of thumb is to go one gig higher then required, since what is listed as required is bare min and will be a bit slow running multiple programs, considering the user I am sure she will be doing a lot in internet stuff Facebook, myspace and so on, so the more ram the better!
BoatBuoy
My guess is you don't need any Direct X drivers. They are shipped in Win7 package like they have been in all OS products since Win98. If they didn't load during the install, your video adapter is incompatible. You're probably going to have to install a later video adapter and disable the onboard if it doesn't happen automatically. On some it does.
PiratePast40
That's a pretty old machine. If you keep researching, you'll find several potential issues. Others haven't had much luck getting the bios to turn off the onboard graphics. Recommended replacement motherboards are AGP so you'll need to open up the case to see if you even have a slot for a pcie card. There's little sense in buying an obsolete video card that you can't transfer to another machine in the future. The chipset may support all DX drivers - but it's up to the date it was manufactured. Sometime around 2005?
Your best bet is to take it into a local computer shop and have them take a look and make a recommendation. Since it's an obsolete and proprietary platform, that's really the only way to know.
