early 90's yamaha 15 won't start.
fun w son
it started fine when i picked it up about 1 year ago.
the plugs are wet and it is not a fuel problem. i don't think it is getting any fire, what and how do i check the electrical????
fun w son
Re: early 90's yamaha 15 won't start.
thanks for the words! i'll give it a try tonight.
JUSTINTIME
check for spark
if no spark unplug the white wire from CDI box
if you get spark, you need to check the safety lanyard
fun w son
thanks i'll try tonight and let you know
sdsaw
If no spark, also check the kill button.
I have a late eighties 9.9 with a red rubber kill button on the tiller handle and it collapsed enough to ground out the ignition resulting in no spark
fun w son
is there a way to bypass the kill botton!!
fun w son
i unplugged the stop switch, and still no blue spark?????
fun w son
when it comes to electrical.... i think i need to bring this one in!!
fun w son
I read though the Manual and it seams pretty easy. I need to Buy a Fluke Meter and learn to use that before i can go any further. I'll keep you informed. Thanks!!!
JUSTINTIME
make sure you tested with the white wire unplugged from cdi
fun w son
i unplugged both wires on the stop botton and pulled the rope with the sparkplug out of the head but plugged in to the coil and got nothing. then i connected the two wires together and pulled again with nothing. i also tried with the stop botton hooked up, and unpluged the white wire from the black ignition box on the back of the motor and still nothing.
JUSTINTIME
ok
trigger or stator or maybe cdi or even a the coil
check the coil grounds
fun w son
i checked them and all was good, one thing a noticed the black box on the top of the head (not the coil) is not tight on one side.it has a little play. i tried to tighten the bolt but it won't tighted any more, now the side with the black wires under the bolt was tight. there was no corrosion on any on the wires that i can see.
