Flywheel Nut Came Loose 1977,200hp Evenrude
Madeira angler
I have a 1977 200HP Evenrude Outboard and the flywheel came loose some how and rotated. Now the engine wont start. I need to know the proceedure to get the flywheel back to the original position so it will start and the torque lbs. for the flywheel nut. Please help me...I dont have a service manual yet...but its coming ! Thank you
Joe Reeves
Re: Flywheel Nut Came Loose 1977,200hp Evenrude
The flywheel nut came loose because the nut was not torqued properly. This resulted in having the flywheel key shear, allowing the flywheel turn somewhat on the crankshaft which throws the engine out of time.
Remove the flywheel and the timer base. Clean up the tapers on the flywheel and the crankshaft. Install a new flywheel key so that the outer straight edge aligns straight up and down with the engine, NOT with the flywheel taper.
Install the timer base, then the flywheel so that it aligns properly with the key, then torque the nut to 145 foot pounds.
Thousands of parts in my remaining stock. Not able to list them all. Let me know what you need and I'll look it up for you. Visit my eBay store at:
http://stores.ebay.com/Evinrude-Johnson-Outboard-Parts-etc?refid=store
