unburnt oil
ron755
I've read alot about blk ooze leaking from the exhaust, but mine is a blue green. like unburnt oil. I sprayed cylinders with fogging oil, waited about 15 minutes, and started engine. I let it run until smoke cleared up.What caused this? Was it something I did? It is a 1990 Evinrude XP 150.
ezeke
Re: unburnt oil
It's normal to get unburned oil from the exhaust on a two stroke especially when running the motor with no load: http://forums.iboats.com/showthread.php?t=207285
You will have less carbon build-up and excess oil if the thermostats are working properly and if you use synthetic or synthetic blend TC-W3 oils.
Some lower unit lubes are colored green so be sure that your leaking oil is not from the gearcase.
psteurer
Re: unburnt oil
What color was the fogging oil? It is probably what you sprayed in the cylinders that was unburned and is now leaking out. Should not be anything to be concerned about. Check the color of the oil in your lower unit to be sure. If the lower unit oil is blue-green and smells the same as what is leaking from the exhaust, then you have a leak there.
ron755
Re: unburnt oil
The fogging oil I used Was a clear brown. I'll go out and check the lower unit oil now. Sorry, I just worry alot. THANKS FOR YOUR HELP
F_R
Re: unburnt oil
You should be aware of how a two-stroke is lubricated. In an ideal world as far as the motor is concerned, the oil would go through the motor unburned and come out the same color as it went in (except for the black carbon particles that it picked up in the exhaust housing). It lubricates all the working parts as it passes through the powerhead.
However, such an ideal world for the powerhead no longer is tolerated by environmental interests. So, an attempt is made to burn the oil in the combustion chambers. What does make it through without being burned is most any color, mostly black or emulsified white gunky goo as it mixes with the discharged cooling water.
The most critical area to be lubricated is the area around the exhaust ports, which is also the last place the oil is used before being discharged. If the oil were to be completely burned in the combustion process, the exhaust port area would receive poor lubrication. In fact, if you tear down a motor, you will find the most wear in that area.
All this to say don't be too concerned about oil being discharged. That is a good thing. If you are concerned about the environmental impact, use a bio-degradeable (synthetic) oil. It produces less sheen on the water too.
