Jon Boat conversion
fishrdan
Re: Jon Boat conversion
Wood and paint will due
Oh yeah, I'm not suggesting you do the carpet thing as it's not a preferred method, PITA to keep clean, holds moisture, etc. I bit the bullet on my jon since I wanted a stealth fishing rig, lots of noise dampening to the hull so my boat was quiet. Tap on the hull and it makes a dull thud sound instead of a tinny ringing sound. I have to admit my jon would be one heck of a lot easier to maintain if I had just painted the decks and forgot about all the noise dampening stuff, but my fishing has been one heck of a lot better with the quite boat.
cvtech1
. Some more pic of my conversion.
cvtech1
The two boxes up front is for dry storage. If you look close above the storage bins there is another storage area you can see the hinges outlined under the carpet this is under the casting deck.
cvtech1
This is the middle area.
cvtech1
Back area where the battery and gas tank are located.
cvtech1
Recently added side console will be painted soon, most likely black like the carpet should of been. But I'm ok with it. Any comments are welcome. Thanks!
