HT32BSX115
- Joined
- Dec 8, 2005
- 10,083
Re: How many cracked blocks this winter?
Very good answer.......
bottom line............
AIR DOESN"T FREEZE!
Drain your blocks!!!!!!
\The one fact that is clear here that some boaters don't want to face is that there are distinct disadvantages to raw water cooled sterndrives...and this is one...they do not forgive even a few hours of a low enough temp...if you want to have no worries about freezing...then get an OB next time...or full closed cooling (still have to drain the raw water section) and that's it....I can deal with it because I have no problem jumping in the bilge and draining it when needed....but some engines have such bad access it's a real pain... but if you're going to own one of these....either learn how and get out there and JUST DO IT don't waste time asking questions on the net...I could drain my engine in less time that it takes to read this thread....or have a good relationship with a shop that will do it for you...
AIR DOESN"T FREEZE!
