Mercury Mark 6 1955 Clutch-Lower Unit
charlie Minter
Hello,
I am rebuilding the lower unit on a Mercury Mark 1955 vin that had a broken clutch cable.
Now that I have the lower assembly unit apart I can't figure out which way the Z shaped steel piece goes that is lifted by the clutch cable.
In the drive shaft side of the lower unit, by the spring that connect the drive shaft to the propellor drive shaft, does the end point of the Z shaped piece point up or down. I have no parts diagram so I've winging it here.
Thanks for any help you can offer.
Charlie Minter
Laddies
Banned
Re: Mercury Mark 6 1955 Clutch-Lower Unit
Hope this helps
charlie Minter
Many thanks!
This completely solves my problem. I greatly appreciate your help with this.
All the best,
Charlie Minter
