what outdrive model do i have?
seadated cutter
this is my first time posting here and just wanted to say this has to be the best forum i have ever seen!
okay to my problem,i have a 1971 chrysler 225 hp 318 engine and it has a chrysler outdrive as well.i cant find a model number on the outdrive so i can find a service manual for it.the block busted new years day and i have to pull it and i would like to locate a manual before i take it on.i am new to inboards but i am an auto mechanic so i do have some knowledge but i would still like a manual of some kind,does the chrysler outdrive cross reference with a vovlo? thanks in advance and i am looking forward to chattin with gals and guys on here.
cbavier
Re: what outdrive model do i have?
seadated cutter
Welcome aboard Iboats
Don S
Post some pictures of the drive.
Don S
Just by clicking on your link I was able to see it's a Volvo outdrive. Which one may be a problem, could be a 250 or a 270 . No way of telling by looking at them. The 250 has straight gears, and the 270 has helical gears. How it became attached to a Chrysler 318, I have no clue.
Ayuh,... It seems I remember that F'inscreenname's hull was originally a 340 or 360 Chrysler ahead of an old Volvo,..??
Don S
Yeah, they did some things with Chrysler, Ford, and Glastron that isn't documented anywhere in Volvo, so while it looks like Volvo, finding parts and what it really is can be a bit of a pain in the butt.
seadated cutter
hey here we go i got it to work,guys thanks for all the help.the previous owner told me he thought it was a volvo but did not know which number.this set up is in a 28 foot cargile cutter if that helps any?
Don S
Look at your drive and see if you can read the ID plate.
attachment.php
seadated cutter
okay i just went out and found the plate and it does say vovlo penta on top the it has the spot where a number should be maybe 6-9 digits but the numbers are gone due to it rubbing that housing right obove the plate so no luck there and then has sweden and somthing at else at the bottom.
Don S
That part above it shouldn't come close to it. If it's rubbing on it, then you have some problems with the helmet bushing and bolt.
Go up to the Adults Only sticky at the top of the forum, and go to the Volvo info. Then find the service mauals for your drive. Download both the 250 and the 270 manuals. They may help determine what you have.
seadated cutter
okay mr.don s i believe its a volvo 270.i have removed the outdrive going by the manual.do you guys suggest i do anything to the outdrive while its off? it was in great working order before i removed it.i do plan on cleaning and painting before i reinstall it anything else? thanks
slasmith1
Change the oil and pressure test it.
Don S
Was there any water in the bellows? If not, replace the bellows and be thankful.
If there was, replace the ujoints, you could also have rust on the yoke seal surface washer on the yoke which will eat up the seal and cause a gear lube leak into the bellows. This in turn could cause drive failure. If water gets into the flywheel housing and damages those bearings, well that requires an engine pull.
