1990 120 VrO no spark
cooldog4
I have a 1990 Johnson 120 V4 VRO looper engine that has no spark anywhere. The problem comes and goes. One day the engine will run like a champ with no issues, then the next day can try all day with no spark. I have fired the motor up in the yard and warm it up, go to the boat ramp takes about an hour and it won't spark, drive back home and try it again it fires up. I have replaced the power pack, stator, timer base, and regulator, all new parts. And I still have the same problem. Can anyone figure this out or recommend someone in eastern NC that can?
Re: 1990 120 VrO no spark
look for a bare spot or bad connection in the Black/yellow wire. that is the spark kill wire.
jonesg
If you don't already have it, get the factory manual
www.outboardbooks.com
when its non sparking, remove the airbox cover.
Unplug the big red harness plug and jump start it at the solenoid.
If it does start you can stop it by blocking the carb throats and flooding it out.
If it runs the problem is in the harness or controller.
If it still doesn't fire the problem is on the engine somewhere.
The manual has some simple troubleshooting tests to trace it .
The_Kid
Check the connector for the main electrical harness. My 1990 88spl was giving me the same problem. Most of the pins in the connector had some corrosion on them. Cleaned them up and used some dielectric grease and everything is working OK now.
