fuel tank sending unit on Sylvan deckboat
jcintheville
The gas gauge does not work. I have looked everywhere on this 1999 Sylvan deckboat. It is a 2230. Can anyone give me some advice as to where I can find the unit?
stylesabu
Re: fuel tank sending unit on Sylvan deckboat
fuel senders aren't specific to hull manufactirs. there geniric.what problem are you having?
stylesabu
sorry, it will be on top of the fuel tank
Ayuh,... Follow the fuel fill hose, the motor's gasline,+ the fuel gauge wire,...
All 3 meet at the Fuel Tank,...
The sender is mounted to the Top of the Tank...
jcintheville
Thanks for the responses. I was hoping there was an entry hole above the sending unit but apparently not or no one is sure. There is a section of the floor that is screwed down and sealed with silicone caulking. I will dig that out and open it up to see if the unit is hidden there.
