25 johnson 1990 idle/running troubles tried everything I can please help
jbjennings
Re: 25 johnson 1990 idle/running troubles tried everything I can please help
Nice to hear she's idling good. I hope you report back about wide open throttle running when you get a chance.
later,
JBJ
985johnm
Where did you get that parts diagram. The bolt I'm looking for should be on it but it's outside the edge of the screen. please help
985johnm
it's no. 28 on the parts diagram. I broke it off trying to tighten it thinking it would tighten up my steering. What does this do?
bktheking
It's the front rubber motor mount by the looks of it, the screw I pointed out is what I believe you need to tighten, the part that adjusts the friction usually looks like what I showed you, screw with a spring to keep adjustment. I don't own a 25 but my 9.9 and 15 have this same screw on the side at the top of the leg with the spring.
Try it out.
985johnm
I'm replacing the motor mount then I'll let you know how it's running
