what do you wet out your fiberglass mat with
snake91876
i am putting mat on my deck i am trying to use a brush i guess i need something else i have to just like dabble it to get it to wet out. what can i use a roller if so what type.
drewpster
Re: what do you wet out your fiberglass mat with
Any cheap thick nap roller should work fine. I bought mine at Dollar General for $2 a pack. Toss them when your done. You do need to be conscience of contamination, but even the cheapo rollers I used worked fine. Pan liners are a plus too, keeps the pan clean for the next go-around.
SKIBUM1M
I used a foam roller from west system. If you need to take a break you can wrap it and put it in a freezer and it will stay soft overnight.
F14CRAZY
Ensign
Yup either rollers or cheap paintbrushes
