Re: Help with minn kota power drive motor
Check the connector for corrosion. Disconnect and re-connect it several times to burnish the contacts. If that doesn't work, it is generally a bad foot pedal. I've taken some of these apart and short of replacing the PC board, they are not repairable. Before you buy a new pedal though, see if you can borrow one from a friend to verify that's the problem. New pedals are about $75. Check right here on iBoats.
