Re: Cam Upgrade
Lobe centers at 113 or more, lift under .500
Cam timing, advancing the cam timing can lower the RPM range that peak torque and HP occur, depending on the power curves of the cam you select you may advance the cam 2 - 4, even 6 degrees to bring the power more into the RPM range that the motor is operated at (4600 - 4800).
Lift under 500
Mild valve springs, you are not going to be turning enough RPM to need much spring pressure.
Edelbrock makes Marine intakes, see if they have an Marine RPM Air-gap.
More compression may need reduced ignition timing, initially set timing retarded 2 degrees and be alert to ANY pinging.
If your distributor is 'points' style, consider upgrading to breakerless and a hotter coil.
Cyl Heads, some truck engines used a cast iron equivalent of the large valve GT 40 alum heads. Clean up and port match, DO NOT POLISH intakes, the rough finish actually helps keep fuel in suspension and provides more power for torque motors. Polishing is for RPM motors.
Carb, Marine version, 750 or less, a 600 - 660 will provide surprising performance. Bigger is NOT better for torque. Vacuum secondaries.
Lift under 500
